I have read most of the past 20 pages and seen lots of the "you must be in a high congestion area" Is there an easy way to find out which areas are heavily congested without having to sign upto them before-hand and checking for yourself? I still have a VM forum account and a moderator checked my postal address recently and said it's fine, then went on to say if you're not happy you can leave within the first 14 days, then mentioned some Ofcom ruling about minimum guaranteed speeds. That minimum won't do me a bit of good if latency and low upload speeds are also an issue during peak times. I was with VM years ago and it was appalling back in 2015 during peak times. I can't say I trust that moderator when they say utilisation is fine. VM was always heavily oversubscribed here back then, can't see that having changed by much since.
