Dry, clear skies, and very sunny but between -5C and 16C in the plains depending on the day, and always sub zero in the mountains.Hows Swizerland this time of year?
You know, surprisingly I’ve never looked backHow could I give up grey skies, dull dismal damp weather, and generally cold and miserable at all times for that?
As requested, door up shots
Shame its so overcast
Both are angled, the drive declines towards the house and the footpath ascends to the top of the drive, one or the other would be fine if the other was flat, but together with the relatively long wheelbase and low clearance on the AV makes it a teeth sucker going over, so will be dropping the footpath top by an inch or two and raising the bottom of the drive and inch and hopefully alltogether makes it a lot flatter and easier to get on and off.
I've got exactly the same setup. Can't get my car on the drive without bottoming out. For ages I used a few sheets of rubber matting to create a bump which lifted the rear wheels, but it was still a PITA, so now I leave mine parked on the road. I keep meaning to get someone to look at the drive, but the only real solution is to lower the gradient...which means lowering the footpath...which means getting the council in to assess it before even getting quotes from driveway companies. Anyway, I'll stop detracting from the main thread content with boring discussions over driveway construction and approach angles now![]()
I just rang the council up and told them I was doing it. They just said as long as its put back to a high standard they dont care.
High standard will probably be better than they do.I just rang the council up and told them I was doing it. They just said as long as its put back to a high standard they dont care.
Gorgeous car. My mechanic neighbor opposite us back in the UK also had a lambo, and it was always a pleasure to see. I like to think he bought it after his Rover turbo sports sedan got blown away by my modded S14a LOL. Dream car of mine. You must be so very pleased.
What am I missing about the crypto title? You mined, or invested in crypto and earned a lot of money making this all possible? (do tell the TL;DR backstory).
Shhhhhhhh the tax man will hear
I'd snap his hand off, I had a look on blackcircles and that varied from 5-800 for crap pirellis.Result!!!
Popped to my local tyre guy yesterday to get the MPS4S ordered, none of the local suppliers have stock in the rear sizes (surprise surprise!) and the one that did wanted 720 each for them.
Left it with my guy and hes just come back with a price.
355/25/21 for £375 fully fitted.
255/30/20 for £210 fully fitted.
The only downside is the rears to get them at that price are an 8-10 week lead time.
So MPS4S are now on order![]()
You have to declare all profit gained after £12,300 on shares if not married, £24,600 is married and if it is from mining then you add it to your income, both you apply on your self assessment, now of course the latter is questionable as to how trackable it is, but I believe Kindai makes his greater money from trading crypto currencies rather than mining himself personally as we both do share trading, mainly on US market in evenings.
Diamond hands with GME?![]()
Kudos to you sir, living the dream YOUR WAY. Do you use it as a daily or is there a ford focus lurking around the corner loll
Well I just took it to morrisons to go shopping![]()
