not planning on overhauling my motherbaord. i got the X570 board for longevity5800X would give you a decent amount more of per-core performance, so if you want that go for a 5800X now.
But if you don't really need that, I'd say either:
- Wait for a 5900X, if you're going to keep your current mobo and memory etc for a while
- Wait for Zen 4 and go AM5 at the end of the year
I would not drop a 3900X for a 5800X, keep the 3900X.
Depends on your use case really and how much multicore power you need.I have been thinking about doing the same thing going for the 5800x i wanted the 5900x but can not find any in stock for my new build to replace my 5820k setup but not sure if 5800x would be the right choice
Be used for a lot of gamingDepends on your use case really and how much multicore power you need.
8 cores will be fine for gaming.Be used for a lot of gaming
I was pretty much set on the 5800X but it seems they run +20C hotter than any of other 5000 chips. Up to 90C under load. That's a bit much imho.
The 5900X doesn't apparently have such an issue, and oddly enough neither does the 5950X.
Not sure if the problem is fully solved by under-volting the heck out of them, but it might be.
