Spec me some matt clearcoat
22 Aug 2010
On the Wagon-East Angular
Hi - I'm in the process of building the Deag Millennium Falcon, to be exact it's now fully assembled and base coated and is ready for painting then weathering. Ideally I want to seal in between the painting process and then the weathering process and then seal the weathering so what matt clearcoat would you recommend?
I have both an air brush and a full size paint gun if the product needs spraying (The model is quite large at 80cm long and 60cm in diameter so not really suited to air brushing I wouldn't have thought? I could be wrong though!). I'm not adverse to using rattle cans if needs be.
Cheers :)
12 Sep 2009
I use Vallejo Premium matt varnish & gloss varnish its designed to be used in an airbrush so no thinning required I just add a couple of drops of flow improver into the airbrush then add the varnish & you are good to go.
Hope this helps
Cheers all
17 Aug 2009
Hope this helps
Cheers all
have you tried brushing on did pick some up but yet to try it
12 Oct 2006
Tatooine
Hope this helps
Cheers all
I picked up both bottles last weekend to start to learn how to oilwash and pin washing. The stuff was super easy to use and had a great finish.
Have you tried the Satin for Finished models?
12 Sep 2009
Not yet but I have discovered Nuln Oil from Games Workshop getting some great results with it :)
Cheers all
30 Nov 2011
Cheers all
if you're not done yet, you can also try abteilung 502 engine grease, or other black oil paints for pin lining and weathering are loads easier, I also use Rob Ross odourless thinner with this as it smells a lot less than turps or white spirit
the advantage of this is that you can slather it all over and then use the thinners with something soft like a sponge to clean it off the raised surfaces unlike washes that you end up having to paint back over to highlight or tidy up
also +1 on vallejo varnish
17 Aug 2009
been using the Vallajo Matt varnish but have been using 2 parts varnish to maybe one part matt medium
brush to apply
