Hi chaps,
Was hoping for some ideas on my latest car based woe.
I have a 2007 my iv mondeo and noticed today that the headlining is sodden. Water is dripping from the apex of the roof and through the rear roof light, and also running down both side pillars to the floor below.
Now this car does not have a sun roof.
To my noddy brain, the only three sources of water can be...
1) a hole in the roof - can't see anything.
2) the aerial rubber perished - yeah it looks a bit old. But this is lower than the apex of the roof, and for water to drip out of the rear roof light it would have to run uphill. Also the front of the head lining is dry (above the windscreen) and this is the first area you would expect to get wet.
3) the rear washer system - now this has not worked since I have owned the car. So there could be a loose pipe somewhere. But the car has been sat for a week or two unused. So I would not expect the car to get wet unless the pump was run!
So all in all I am a bit stumped. This is no condenstational (judging by the amount of a
Water) any advise would be greatly appreciated.
Thanks
Thanks
