Hi All,
I'm looking to upgrade my motherboard and CPU and would like some advice please.
My current system is as follows: (PSU is different from below, I swapped it for an 650w Gold Modular)
I would like, if possible to just upgrade the motherboard and CPU without the need to upgrade the PSU. I would also like to use a stock cooler if its efficient enough but don't mind upgrading that if I have to.
Budget is £500 if possible and I'm open with going either Intel or AMD, the only issue with switching to Intel is I was under the impression if I did that I would need to change my RAM too, is this the case?
Thanks for your help, it is most appreciated.
Lee Ince
- 1 x AMD Ryzen 5 Six Core 1600 3.60GHz (Socket AM4) Processor - Retail
- 1 x Gigabyte GA-AB350-Gaming 3 AMD B350 (Socket AM4) DDR4 ATX Motherboard
- 1 x Team Group Dark Pro 16GB (2x8GB) DDR4 PC4-25600C16 3200MHz Dual Channel Kit - Black/Red (TDPRD416G32
- 1 x Bitfenix Formula Series 650W 80 Plus Gold Power Supply
- 1 x Samsung 250GB 850 EVO SSD 2.5" SATA 6Gbps 32 Layer 3D V-NAND Solid State Drive (MZ-75E250B/EU)
- 1 x Seagate BarraCuda 2TB 7200RPM SATA 6Gb/s 64MB Cache HDD - OEM (ST2000DM006)
- 1 x Asus PCE-AC51 Wireless-AC750 Dual-band PCI-E Adapter
- 1 x be quiet! Pure Base 600 Midi Tower Case - Black Window
- 1 x Gigabyte Aorus GeForce GTX 1080TI 11264MB GDDR5X PCI-Express Graphics Card
- 1 x Akasa VR USB Panel 3.5 Inch - Black
- 1 x Akasa 5.25" Bay SSD/HDD 2.5"/3.5" Device adapter - AK-HDA-05
- 1 x AOC Q3279VWF 32" 2560x1440 VA 75Hz FREESYNC WideScreen LED Monitor
Lee Ince
