Permabanned
- 23 Apr 2014
- Hertfordshire
Reset to default settings, set core -250, open curve, drag 850 mark to around 1900 ish, click tick, done.
Mine has been fine so far boosting to 1905 ish at 850mv.
Hi Chaps, sorry if this has been covered already but can anyone point to a decent make of a 3080FE 12 pin to dual 8 pin extension cable in white?
I've seen one listed at the rainforest but I've never heard of the maker and I'm not going to trust my 3080 to an unknown provider.
Although I decided to go with a lower clock speed/voltage so I can keep the card below 260w, 320w for an extra couple of % isnt worth it for me.Thats a damn good card I reckon, apparently my 0.882v is better than what most are setting to, so if you are stable at 1905 with 0.850mv well done.Although I decided to go with a lower clock speed/voltage so I can keep the card below 260w, 320w for an extra couple of % isnt worth it for me.
Ran a few benchmarks and played a load of games without issue is all. Originally I tried 825mv but that crashed so bumped to 850 and no issues.Cant say I have scientifically tested it as such.Ran a few benchmarks and played a load of games without issue is all. Originally I tried 825mv but that crashed so bumped to 850 and no issues.
If core clock shows Curve then its done but yes you need to drag it up to 1800-1900mhz wherever you want to set it. You can always click the round arrow to reset the settings and try again.
What's this mod? An underclock?
Would it work on the stock overclocked MSI Version of the 3080
Undervolting the GPU to run cooler, use less Watts but still maintain and in some cases improve on performance and works with any 3xxx series card, (and others)
How pls?
