 - 20 Oct 2002
 - Oxfordshire / Bucks
For £10k? Not really. You'd get a better car from the other manufacturers you've mentioned.
Definitely change this criteria, maybe use it to make an ultimate decision if you must but don't exclude cars with over £30 tax out of hand, especially as you want a petrol automatic which typically have slightly worse fuel efficiency stats (and hence potentially tax band). Plus as you've alluded to, you could actually be missing out on newer cars because of that, you can probably get a 2017/2018 SE L trim Octavia for your budget but you would exclude it due to tax...
thanks to you both
i will update OP
id love 1 series, pitty i cant stretch to it, ive driven one, and thought "best car ever" and it was a diesel ! (auto)
 - I pulled away from a roundabout thinking the person in front had gone and they hadn't.
 but the higher spec Pulsars IMO manage to avoid that.
