My speed issues with virgin have gotten way worse the past couple of weeks or so. I'm getting about 40 mbps at peak times now, I'm on m600
I have the Hub 3.0 and the wifi is awful, is there a relatively inexpensive solution for better wifi coverage? Does it literally involve turning it into a modem only then plugging it into a different wireless router? If so would I then unplug my ethernets from the Hub 3.0 and put them in said wifi router? I'm on m350 speed.
Thanks in advance!
You literally activate modem mode, the hub reboots and you connect the bee router. However if your issue is WiFi coverage, then run a cable to a central point (ideally upstairs) and install an AP, it’ll make the world of difference.
Renewed this week and had to get in touch again as I removed movies and added sky sports. Movies was both HD and SD but Sports was only added as SD, another 7 quid a month for what really should be the standard these days. Got 2 months of it credited going forward but still not happy with this nonsense.
I have surround etc setup with ceiling speakers etc and with the SD feed the sound is at best stereo, on HD is it pretty decent in comparison with each speaker firing independently as you'd expect. To me SD shouldn't even be a thing any more if most content is recorded or broadcast via the HD kit.Blame the content provider - they dictate the terms of supply and always have sadly, including the requirement for an additional payment for HD. Admittedly VM do a questionable job of re-encoding feeds and the hardware upscaler in the box isn't the best, which doesn't help the quality, especially on the SD side.
Why is it so hard to see their packages? On their site you have to put in your postcode and all your information so they can call you in 10 days?
Every other provider just tells you what you can get? Is this genuinely the only option?
Can you not just connect to your phone hotspot which should then bypass the lockoutIt's even harder if you are a customer virgin wishing to look at the packages they offer, they completely lock out the store from the navigation of the website! It's impossible to navigate to.
This is what you see when you are on Virgin. Note, I am not even logged in, and there's no cookies either because I have never accessed the sign in options in this browser. They just completely lock you out of that part of the website.
Just click "Expanding our network" then you'll see the Bundles Broadband TV Phone options
I'm just going to put it in "Modem mode" and connect my Unifi AP x 4 to it really
