Hi all.
I just wanted to reiterate to all concerned about the importance of reapplying thermal paste.
I've had my 9900k for around 2 years and my strix 1080ti from launch and decided the other weekend to reapply the thermal paste on both with grizzly kryonaut (I'm not endorsing just this product but this is the one I used) and my temps have gone from 85 degrees at 100% usage to 70 on the cpu at 4.8 and from 70 to 60 at 100% GPU usage.
This may not be ground breaking to all of you but I feel it makes a huge difference. My GPU can now overclock to way over 2000mhz and the fans on my CPU cooler don't make anywhere near as much noise.
Not only will the silicone last a bit longer but for a little bit of messing around everything is running cooler and more efficiently.
It's worth it
Have a great day all!
It's worth it
. Have a great day all!
. I have some thermal pads coming next week and a new tube of Noctua NH1, so I am going to strip and clean my system and repaste my cpu and my 7950, which has never been done and gets a bit loud and toasty.
