Will the parts work?
21 Mar 2016
**No Competitors**
It gives me an error saying the cpu wont work what should I do? I dont have a second cpu to load the new system to be able to fix the problem
They're fully compatible.
And anyway you can flash BIOS of that board even without any CPU.
X570 Tomahawk was released only year ago with Zen3 already visible in horizon.
So very unlikely that you would get board with too early BIOS to support 5800X.
This is how BIOS USB Flashback works:
can i install the 5800x and cpu cooler and do this or do i have to do it before installion of the cpu
Yep. you'll need to download the latest bios for your motherboard from the MSI website (MSI X570 MAG Tomhawk) if I'm correct?
BTW the reason why the link is starred out in the OP, is because the site is banned on OCUK forums.
yes about to order the parts now, how to i paste my basket into a post to show you what ill buy
Haha its wrong! i changed the SSD to the black one because apparently it's slightly better? i need to find a decent case and im ready to order. apparently my corsair 400c old case won't be able to fit the parts. ugh. i love the corsair 400c case purely because of the side panel door.
are there any cases similar to this one? i'm saddened by this. but i won't edit my build just to make it fit in my case lol
What wont fit in your case because of the side panel ?
Looks to me like it will fit the 400c unless I'm missing something.
I answered that question in the thread you posted in the case forum. 275R would be the 400c replacement but that's more or less the same size. 4000D is a little bit bigger than the 400c but I don't know what you have planned apart from the bit you have already picked. You could go the whole hog & buy a 5000D which is a fair bit bigger.
