Yes each card has different quality silicon, so this may not be a good profitable experiment sadly.
My profile 1 I didnt change anything, I just saved it, so I had an easy way to get back to my card's stock. So either your card has a different voltage curve to mine at stock or maybe you previously had a higher power limit or clock boost dialled in? as it would reset those also.
I would not want to overclock my card , that's why I got the overclocked version. It runs at 73c max with 70% ish fan speed so I'll just stick with this. And with 40% fan speed 76c. It's ultra silent.
But the card doesn't like to be given low voltage and and lower clocks speed and perform better than normal. But it makes sense to me.
Oh well, was looking forward to an undervolt with some boost
