Man of Honour
- 20 Dec 2004
- Tamworth
First things first.
I already have a BK Gemini II which I have to say does a decent job.
As it stands I can only site a subwoofer in once place in the room due to room layout and keeping the wife happy. Also due to keeping the wife happy the subwoofer is hidden under a wooden box that matches the current furniture.
The likelyhood is that the living room furniture is going to be replaced at some point in the near future and the box covering the subwoofer will go. This means the small black ash BK Gemini II also needs to go, and my wife has agreed to a glossy black subwoofer in it's place.
This has basically lead me to the BK XXLS400-DF, which is glossy black on the front and both sides. It is also of a similar size to the box covering the existing subwoofer at around 40 x 40 x 46 cm (the box is 35 x 35 x 50cm
Anything front firing is out because she doesn't want a speaker grill on show.
The Monolith and Monolith Plus are too big for the space available.
AV set up is for movie watching only.
The other speakers are 5 x Q Acoustic i7000 and a pair of Dali Alteco heights and are unlikely to change at all due their to wife pleasing size and not breaking the bank.
Amp is Denon X2300. This may change but only to add more two channels for rear heights.
TL;DR
Is there anything else I should consider apart from the BK XXLS400-DF that is:
Down firing, glossy black finish, a footprint of around 40 x 40 cm and preferably less than £600.
Thanks
TL;DR
Thanks
2021-03-29_06-31-08
. I wouldn't be able to fit another sub in anyway as one wall is open plan so no space for a sub. I'm not sure what I'd gain, it's plenty loud for the room.
