How's the Canyon? Thinking of getting the frame and building one up.View attachment yDtzlqO.jpg
This did the job for me today. Had my phone in it and the GoPro on the new mouth mount, could whip it out and put it back one handed, nice and easy
The Dimension NDR is the best I’ve found so far
Nope. That's another tool I needNot surprised your guy doesn't want to give it a go - after seeing that video (if he's seen!). Totally agree not worth the stress of going through that, but then the fact it seems much better/resolved now with the old bearing in, possible the replacement you got isn't exact size? Got any vernier calipers you could confirm it with? Could just be the bearing is crappy/junk and couldn't handle the pressure.
But yes.. think I'll get some new bearings and pop those in the hub. One thing at least is it's super quick to dismantle the hub. Literally just pull things off. I think I can even pull the freehub/cassette off together. A lot less faff than some wheels that require two spanners either side and an allen key etc.
Can take a while for your arse to get used to the new shape so give it a week on it before changing?
Don't forget the Mech hanger! But probably a loose spoke or valve nut, but of course you checked those firstStarted getting a little noise, I think it’s rear spokes because of all the mega watts I push obv. It’s that kind of ting noise
Going to do the obvious, chainring bolts, skewer, check cassette tight, chain is freshly waxed, but I’m fairly confident in my diagnosis.
Was a bit like that today, I flew down to the office and it felt cool so even put leg warmers on... Big mistake! Even at 7.55am it was about 12 degrees! So riding back at lunchtime with the thermal shorts and thermal windproof jersey was a little more leasurely. Although wind was cool enough to practice a 'suicide pull' on the way back (prior to a Zwift event tomorrow), once I was out of the wind and in the full sun it was boiling hot. Easily 22 degrees in my south facing rear of garage/rear garden away from the winds. T-shirt weather!Wasn't that bad compared to today that was tough! Had that horrible mid temperature where I was sweating loads but needed layers as the wind was just cutting through me. Nice to have the tailwind for the 10miles back from my parents.
You timed that perfectly, kudos in advance on the start of your tanlines!Got the next few days off work and looks like temps might be touching 20C
I've got 'Selle Italia Max Gel Flow' or something. Looks similar to this one but don't recall mine being a 'Flite' so possibly the precursor, it looks like it though: https://road.cc/content/review/2899-selle-italia-max-flite-gel-flow-saddleSomeone else said that to me. I think the fact it instantly feels a little too firm means I will try one of the Selle gel next, but wont totally write it off yet.
I uhm.. went out in fleece lined leg warmers and fleece lined jersey earlier. I figured only 12C when I started and yesterday was also 12C and cold.. lol. Wind still high. I sweated a lot.You timed that perfectly, kudos in advance on the start of your tanlines!
