Deleted User 298457
Deleted User 298457
Is there a tutorial? I have my Mum using one of these and did it manually, but ADB sounds much more effective.All done via adb.
Ha thanks. Rabbit hole incoming.I won't be able to remember them all tbh but the SNKRS app, End clothing (I have 2 accounts plus my GF has one so 3 Ls there), AFEW, sneakersnstuff, 43einhalb, offspring, size.. there's quite a few. I just draw the line at bots for some reason.
I'm a 43 year old man with a proper job, I'm not going that far for a pair of trainers.. eventually I'll either do what I've done and go to stockx if they're something I believe i HAVE to have (bacons have been that for a while) or move on and if I see really good reps perhaps consider that.
Thank you!
I just use SNKRS and SNS. Will have to check out End Clothing
Bespoke, made out of oak by the landscapers.
They weight a ton and have been the source of much debate/argument... I honestly dread to imagine the cost, it's wrapped up in the full rework/landscaping/garden room/patios etc. I think I have about £100 a panel somewhere at the back of my head but it's hard to pick out the specific number in the overall price.
We've gone full grand designs, timescale/budget out of the window pretty much on day one.
Thanks, they look quality, we just have the standard panels that fall to bits after 6 years or so, I guess what you have will last ages.
Bought some plywood and built a wall to hold my tools:
Plywood wall put up and some french cleats:
Built some tool holders and attached them to the wall:
These are one pair in my collection that I'm yet to wear purely because I paid retail for them... £110, they're worth circa £1400 unworn.the SB Janoski Airs have to be some of the most comfortable trainers I've ever owned!
I wouldn't have skated in them though. Fresh grip tape would have your toes showing after a few sessions
It's not nerdy, they're the only pair I'll postIsn't there a dedicated thread you guys can get nerdy on overpriced foot wear?![]()
Leave me alone!
Really great job on that, nice work
You know you can’t expect to be left alone on here!
No image
