Forza Horizon 4 Bench Thread
@Kaapstad - fixed
Sorry its a link and not embedded image, cant ever get it to work
https://~ibb.co~/rt5FPwb
1440p
Radeon VII @1800/1050 (undervolted)
Ryzen 2700 @4.05
20.12.1 Drivers
3080 @ 1815 MHz - whatever the default memory clock is, how do I find this out?
5600x at default settings
16GB RAM
Re-size bar ON
3440x1440
Driver 465.89
load up afterburner or gpu-z for your clocks and temps.
nice improvement. Stock memory clock is 1188mhz which is DOUBLE DATA RATE and Quad pumped. so 2x then 4x
giving you = 9504mhz
you need to OC that CPU first, tighten up the RAM timings and then OC the card and you should see 20% - 30% improvement.
1440p
5950x @ 4.9 - PBO
2130mhz / 5375mhz 3090FE "mining edition".
32GB - 1900mhz CAS14
nice SAM boost, almost 10% . love my SAM
Still untouched at 4k. 2nd place for 1440p.:cry::cry::cry:
https://i.~ibb.co~/Y8cxLXf/2021-04-03-1.png
6900XT toxic doing its thing.
21.3.1 drivers
5950x PBO
1080 2800Mhz Core 4300 Memory
https://~ibb.co~/x5tHTqP
1440 2800Mhz Core 4300 Memory
https://~ibb.co~/4TZvFZW
4k 2820Mhz Core 4300 Memory
https://~ibb.co~/q0pz9Cj
Yup will need to play around with cpu a bit now, just going to go for a good undervolt and locked clocks like I did with the 2600, seems to work best I think.
RAM wise, mine is nothing special, just team vulcan with a 3000MHz XMP profile, RAM is the one thing I never manually do as just too much room for error imo.
21.3.1 drivers
5950x PBO
Great scores sir, i can see i have some competition on my hands.
I will say though, never underestimate the Merc.
Are you on air or water?
Thanks. It's the 6900xt toxic so has factory fitted AIO water cooler fitted.
The Merc is definitely very good. The best air cooled card I think.
Toxic down. retains the 4k crown.
Only matt and LN2 awaits. :D:D
5950x @ 4.9 - PBO
2145mhz / 5425mhz 3090FE "mining edition".
2160p
https://i.~ibb.co~/GRFv5h6/2021-04-03-3.png
This is about the best I can get at 4k.
21.3.1 drivers
5950x PBO
2860 GPU, 4300 Memory
4k bench
https://~ibb.co~/QPv8qDM
Might be able to do a tiny bit more if it was cooler but it's about 25c in here now so not helping! I put the fans to max for this run and it sounds like a jet engine.
21.3.1 drivers
5950x PBO
4k bench
That's a good score.
I suppose we have to let @Dontrocktheboat win at least game benchmark. :)
I can't get close to your 1440p score. Infinity cache doing its thing. 7.5% up in 1440p
5950x @ 4.9 - PBO
https://i.~ibb.co~/sHwfysm/2021-04-03-2.png
Oh, i love would to see your 1080P score. :)
I am tempted to have the window open and see if it helps when the cold weather arrives. I had firestike running at something crazy like 2950mhz target when it was cold before. I think even if I do though Dontrocktheboat probably still has a bit in reserve to beat me :)
Yep it's a good score so will be hard to beat. A cold run in the morning would get you closer i suspect.
I have beaten your 1080P and 1440P scores, but can't quite reach you at 4K. :)
