No power but I've used 2 psu's
It sounds like you have a short or a component incorrectly fitted. I would go over and recheck everything like cpu, ram and power leads. Also try removing the gpu to see it that helps.
Failing that, remove it from the case and set it up on top of a box and try it.
What ever it is, it's tripping the power supply.
So I've taken the components out the case and tried booting using the SFX power supply, nothing, however when the corsair is plugged in it does the slight movement like in the video above no luck with anything else happening though..
I done the below
- Reseated cables
-reseated RAM
- Reseated and Repaste CPU
- Removed GPU
- Built Outside case
Anything else to try, still a flashing CPU light on debug lights
Are these all new parts, or known good?
CPU type? Check for bent pins in the socket if LGA, and if AM4 check for bend CPU pins.
System spec please.
Looks like power delivery to the motherboard or cpu, psu ruled out as you've tried 2. Im guessing the short has taken out a component on the motherboard or posiblilly the cpu.
PSU and Board is brand new, CPU was from MM and the RAM was from my other pc which was running this morning so I know its not that at fault
System spec please.
Specs are:
Ryzen 2600
Gigabyte B450 Aorus M
16gb Corsair Vengence RGB Pro DDR4
BeQuiet Sfx-l 500w PSU
MSI 2060super ventus
Did you use the cables specific to the PSUs? They're not interchangeable. Hmm.. have you tried a new power cable? The one from the wall to the PSU.
So you don't know if the CPU works? Did you double check for bent pins?
This was the first time of using it, not sure if its working tbh.... I did check the pins and all looked good no bent pins or damage... I still have my Ryzen 1200 here I could put that in the board tomorrow and see if it boots..
Yeah the cables were the ones from the factory box, it came with 3 kettle leads, 2 were normal plugs and then the other was the 2 pin socket for other countries
no power and cpu light flashing, it made a sound like an electric shock when I first hit power button
Something shorted when you first turned on the power and you may well have fried something. Are any bits of the motherboard touching the case? are you sure all the cables are connected correctly? (someone plugged their 8 pin PCIe into the 8 pin CPU power in a recent thread for instance).
I've took it all out of the case and all stand offs are correctly installed, I will double check it was the 8 pin for cpu but I'm sure it was the correct... I will check the cpu as I'm putting my old one in and trying later
