P500, can't get RGB to work
What motherboard have you got? There should be a rgb connector, its 4 pins, check your manual for location.
As I said above, I checked my manual. I'm either completely stupid or I'm blind.
MSI Tomahawk x570.
This is the only place i could find and it doesnt work
YJwFUGm
https://imgur.com/YJwFUGm
I just plugged my AIO rgb connector into the same slot as you have and it worked straight off. (Different board though) Are there any bios settings you have to toggle on?
MSI Tomahawk x570.
YJwFUGm
The Jrainbow you have tried looks to be correct (and 5v). have you tried the other Jrainbow at the opposite end of the motherboard, and i assume you have tried to enable the RGB in bios and /or MSI software
I fixed it. I'm so dumb, amongst the bunch of cables there was a sata cable which needed to be connected to the psu.
you shouldnt need a SATA cable, its gets the power from the header. the SATA cable would normally used if your controlling the RGB from the case
