Don
- 20 Oct 2002
- Oxfordshire / Bucks
it should be in your handbook / service book ?
I believe any oil is better than no oil.
If it was me I would have got a 1l container, topped it up and then booked in for a proper oil change.
Yeah. In some cars the light coming on does not mean it's low and to top it up....it means like....warning you will **** me up, stop.
In the manual it says in an emergency you can use up to 1l of any oil to top the car up between services. Any more than that and you need the PD specific 5-series oil.
some top up in emergency is better than none. Your last point of more than 1 car a year read out of context is quite funnySeen an episode of the Car Wizard on YouTube.
He said he’s seen grown men fight over oil discussions.
I do what I thinks best, don’t always follow manufacturers instructions (if anything I change more frequently not less).
If my engine breaks as a result, I will blame myself.
(No problem yet, 39 vehicles and 32 years driving.)
Trust this man who hasn't made a car last a year!
Your last point of more than 1 car a year read out of context is quite funnyTrust this man who hasn't made a car last a year!
I'd top up with what you have and then get it switched out at next service for the recommended stuff.
Funny that ! But apparently oil doesn’t matter.A good example of using the wrong oil was the Ford Galaxy that had the the VAG PD diesel. A lot of these in later life had cam shaft damage as the Ford dealers put in the Ford oil which wasn't designed for PD engines.
