- 22 Feb 2014
Line = BT Infinity 2
old router - Draytek 2850n
new router - Draytek 2862AC
problem, old router has wifi bugs (one of the main reasons for the upgrade)
new router has been having frequent drop-outs, it can be 10 minutes or 2 hours, during working hours the resolution has been to plug the old router back in and suffer the wifi issues.
New router syncs at a higher speed and when I do a speed test is around 2mb faster.
Layout of the menus is very slightly different so trying to figure out if there is a setting I have missed.
Also trying to understand the stats page (attached)
Using Syslog, it shows a constant stream of information under the WAN tab, until the net disconnected then it just has the single entry showing WAN1 is disconnected.
I connected the new router last night around 21:30, and there was little to no net activity until 10am this morning, net dropped out just after 13:00, powered router off and back on and it wouldn't connect, so put the old router back in place and it connected straight away.
