- 28 Nov 2018
- Monstrocity
Not really, fair enough, no relatively quick & easy FPS boost for me![]()
Oh, but there is! Play in 1080p.... [/trolling]
tricky could always try gigabyte direct and explain the issues with the shop. hopefully they will be able to sort for you if the shop cant.yeah even reinstaled windows
still having the issue just with customer service with site i got it from hoping for a refund because as the above post show everything out of stock![]()
Somehow got a 6800 on AMD today, would a Corsair RM650x be good enough for it?
so just a little update on my situation with the 6800xt
i might have found the problem after 2 days of hardware and software changes os reinstalleds
i uninstalled windows update 'kb5000842' and seems (atleast for the last 2 hours of gaming) fixed my issue
edit scratch that back the black screening![]()
It's even worse when in silent mode it'd a instant crashAs i asked above, have you set the card bios to 'silent' rather than 'OC'?
Is it feasible to try the GPU in a completely different system with a different PSU etc? Should help confirm if the GPU is faulty.It's even worse when in silent mode it'd a instant crash
Care to expand on this? Sounds like coil whine. What PSU was present in the second system?so i put it in my second pc last night but turned it off stright away i was geting a super high pitched sound coming from the graphics card
hoping the site where i got it from will respond to me finaly
Seasonic focus 750 goldCare to expand on this? Sounds like coil whine. What PSU was present in the second system?
Sound like you had a faulty GPU then, it happens sometimes.Seasonic focus 750 gold
sadly decided to give up on the graphics card finally sent it away for RMA a few days ago it was just getting worse it seemed it was instant crashing in the end on both systems
pretty annoyed prob will stay away form amd gpus again for awhile back on my 1070 still love my ryzen 5900x tho
TROH application. Upgraded my rig this week, finally got home
https://www.reddit.com/user/Torrfel..._medium=ios_app&utm_name=iossmf&utm_term=link
Hi Guys, I'm an owner of a powercolor reference 6800xt. I was looking at this video bench here:, and I noticed that with the same card and same exact graphic settings I'm getting on average 10-15 fps less. I got a 9900k to pair with my gpu at 4.8 on all the cores. Is that possible that this guy with a 3950x is getting more advantage with the sam enabled? Otherwise gpu overclock wise, I'm boosting more core clock ( 2640 mhz levels).
