Caporegime
Worn shocks can also cause that. Just to add confusion.
Yeah I saw. Honestly, the car has always had vibrations, especially around 70-80mph. That's the reason I had to do 100mph, honestly sir!Worn shocks can also cause that. Just to add confusion.
Oh, I see what you mean now. Yeah, that could be due to the fact the wheels weren’t round, hence me getting them completely refurbished in the autumn. Pretty sure it was only the fronts though as those rear tyres have never been up front. Also I do run slightly over as mentioned above.
I noticed the little flat spots when I had them in for refurb but it does look properly ****** in that photo
Like I said, wheels were oval and the rear suspension is likely knackered. I’ve done over 70,000 miles in this thing since I bought it and have done zero to the rear other than a set of pads 4 years ago. It’s literally only been routine servicing and some tie rods up front a year ago.
apologies @telewebby and @no idea what
Bloke in the Audi workshop said not to bother unless it fails its MOT. As you were, gents..
Actually, how would I know they've failed, other than a bouncy rear end (and poorly worn tyres )? These are gas struts, so they wouldn't leak oil surely?
