- 19 Jan 2021
I bought a new pc, mainly cos it was the only way to get a 3060Ti. The original CPU, a 3600, temperatures when watching you tube would reach 60C. Playing Total War Warhammer II took it to 90C and then the PC started to turn off completely.
I had already bought a 5600X so flashed the bios and fitted that. Temps are still very high. I think I have 2 problems:
Some ideas I have thought of:
- The case a Aerocool Shard RGB Tempered Glass Mid Tower Case - Black has very bad air flow, it looks pretty but the 3 front fans can only draw air in from tiny side grills
- The wraith stock cooler
- Getting a single fan aio cooler, mounting it on the back panel and putting the fan that was there on the top to draw air in.
- Getting a decent air cooler and adding an extra fan to the top to draw air in.
- Getting a 240mm cooler and mounting it to the top
