After a recent upgrade of my stero amp and speakers I've been back into music in a big way.
My main source of music is either CD or Tidal Premium with Master/MQA and Radio 6 via BBC Sounds app.
The amp is a Rega Elicit-R, so analog only inputs. So to give me the ability for BT streaming I purchased an ifi Zen Blue, which to be fair, works great. For convenience, streaming Radio 6 and for background listening it's perfect, but when sat down to "listen" to music for an evening I do think connecting the phone via wired (headphone jack to RCA phono) does give a better presentation. The BT just seems a little more "flat" whereas the wired just has a better depth of soundstage.
But, I do think the headphone jack on the phone is a little weak, you certainly have to crank the volume on the amp compared to BT or CD input and I'm wondering if I'm also hearing the limitations of the phone as a musical DAC source in general (when compared to CD use)
The phone is a Note 8, it's a few years old now and the battery is pretty shot, but I would have thought it's of a decent spec.
So I've been looking at wired external DACs and the questions I have, after the initial one of - will an external DAC improve the sound? are :-
Will the phone output via it's USB C and would that be better than the 3.5mm or make no difference?
I'm reading some info that makes it sound a bit patchy outputting audio via USB on Android phones and that they don't automatically work with all models of DAC?
Do I need an "OTG" cable for audio rather than a general USB cable?
On first look a couple of DACs look interesting :-
Cambridge Audio DacMagic 200M
Pro :- RCA outputs/MQA native decoding
Con :- The USB input is B, so I would need a USB C to B cable (OTG?)
Chord Mojo
Seems a popular portable DAC, though I'm not really needing it's portability
Audiolab M-DAC+
Pro :- Lots of inputs
Con :- Expensive, only has a 6.3mm output
iFi Zen DAC
Pro :- USB 3 input, RCA output
Con :- Why did I buy the Zen blue....
Chord Mojo
Audiolab M-DAC+
iFi Zen DAC
		 I was playing with the phone BT settings the other day and can turn it to LDAC, which was an improvement over Aptx, but on poking around in the developer settings and upping the bitrate to max quality, it certainly showed the limitations of the phone as a source!
 I was playing with the phone BT settings the other day and can turn it to LDAC, which was an improvement over Aptx, but on poking around in the developer settings and upping the bitrate to max quality, it certainly showed the limitations of the phone as a source!  So yes, I can see now that's a non-starter and I am keen to maximise the quality, but I may have to begin at a slightly more modest starting point....
