 - 22 Mar 2009
Your voltages are perfectly fine.
Its current not voltage that kills a cpu and spiking at 1.5v for small periods is what my 3900x does as well.
Your instability is most likely a ram issue.
Are you using a xmp profile?
Right ok, what I do is disabled xmp profile on D.C.O.P and leave everything on auto default with stock speed and see how it goes, if the pc does shutdown again then I have to RMA to overclockers possible to sent back memory ram but strange as I did memtest86 v9.0 and ran it overnight with xmp profile enabled and it all PASSED with no issues.
Here is image below with xmp profile disabled as it ran at 2666MHz instead of 3600MHz but strange why the highest core clock still below 4400MHz as it only max out at 4391.7MHz?
	Should I be worry about power reporting deviation below (showing red)
