Why do you need Titan that you can't get from a Quadro Kapstad? If it's for your business, surely the Quadro RTX A6000 is the better option - it uses 50w less than the 3090, never mind the Titan and it's a fair bit faster than the 3090 in work, I've seen benchmarks showing it's 20-30% faster
Huh? A 3090 absolutely murders a Titan or Quadro RTX 6000 in professional renderers. Redshift vulcan test scene benchmakrs below, typical of results from other renderers:
RTX 3090 - 161
Ampere A6000 - 174
RTX 3080 - 189
RTX 3070 - 252
Quadro RTX 6000 - 255
Titan RTX - 256
RTX 3060 Ti - 267
Quadro RTX 5000 - 358
An Ampere Titan has literally no reason to exist. There was never a leak for it - these often get confused with workststation cards like the 48GB A6000, and like the 3070 Ti 16GB / 6144 CUDA cores turned out to be the new A4000 lol. For pro workstation use the 3000 series is already far superior to Titan, and niche apps like Solidworks will be served by the A4000-A6000 series.
