Possibly all them but weight is an issue for cost of shipping and risk of damage also.
I had the 19' Mitsubishi Diamond Pro. Playing Unreal Tournament @ 1600x1200@75Hz, was the 4K of its day
..never could get used to the very faint thin 'wire' that ran across the width of the screen, about a third of the way down, though. People said that you just get used to it and stop noticing. but for me it was a case of nope, what was seen could not be unseen.
You will find if you installed the proper driver it supported 1792 × 1344 same as my 19NF (Pro was higher model), Max Res vs Max Recommended Res.
The HZ would be little too low on my Plus at 68HZ so better off with 1600x1200 but your Pro did higher HZ at each RES AFAIR.
Was it a 920 or 930SB (the latter did 1920x1440@73 HZ) so 1600x1200 would be at least 85HZ?
I highly recommend you sell the 49" LCD & 55" OLED and replace them with 15" CRT'sUgh, picturing a CRT next to my basic Samsung 49" LCD or the 55" OLED, I'd want to chuck the CRT off the balcony, just out out out get outtt
I remember in 2004 or 2003 buying a 15" CRT from my school for £10, I had dual 15" monitor setup, cool at the time, but jesus christ the amount of wasted space, I will never miss anything like that, ever.
We had a call out to a Grundig 37" CRT back in the day. Converted barn and this thing was upstairs. It came with handles that you had to bolt underneath to lift...MentalThat Sony 43" CRT weights 200KG![]()
LOL my mate dad used to have a 37" Toshiba CRT 4:3 back in them days..We had a call out to a Grundig 37" CRT back in the day. Converted barn and this thing was upstairs. It came with handles that you had to bolt underneath to lift...Mental
I got a 25,000 volt shock of one as I wasn't paying attention whilst discharging the tube to replace the LOPTX
How do you think they workThey must use a lot of electricity
I used to have a 32" wide flat screen CRT Toshiba upstairs in my bedroom
