Designed for amd because you say so?![]()
Because Crytek (the developer) said so
I like how pretty much immediately that truck on the right has a lot of detail pop-in as he walks along. The grill on the front is virtually non existent then it just "melts" into view.
For Rt games or apps AMD cards slower thats accepted. Also 6900xt seems to have problem with higher frequencies. Maybe it needs more power don't know.
But for me 2750mhz is stable with my 6800xt.
Here is 4k ultra Valhalla:As you can see only 72c and fans are auto my daily settings. Never got crash before.
It's rare to boost that much with other games. For ex; cyberpunk averages about 2730mhz. Using MTP for more power also increases frequencies but only up to 2750mhz not more.
I believe if there is no 2800mhz barrier at time spy 6800xt can beat ln2'd 3080. (already beat every other 3080's)
You are using Manual Tuning Control in Radeon Software correct? What voltage have you set for 2730mhz? I think it's possible to undervolt while raising frequency speed for these cards.
Hey alll!
So bringing back this thread from the dead
With all this mining craze ... I've been offered to trade my Suprim X 3080 for a Red Devil 6900XT.
What's your opinion on this? I don't do mining and I play at 1440p. Ray Tracing is not something I suddenly need because the games I play are competitive and don't use it ... but i'm torn. I know 6900XT has better performance at 1440p but really wanted to understand if anyone here experienced both cards and what was the outtake.
Thank you!
It wouldn't be a downgrade for him based on his use case. It would more than likely be an upgrade.It's definately a downgrade along with the issue of warranty.
6900 xt improving with every driver release, very close to beat 3090 in pure rasterisation right now, i think it will age much better than a 3080.
What do you mean by warranty issue?
Raster is king for competitive games though which is what @Postmodum said he plays.6900xt is worse in every way that matters ( slightly higher raster perf is worth nada ).
Warranty doesn’t transfer over.
Plus RT and DLSS vs crap RT and no DLSS on 6900xt.
DLSS in VR starting to show up as well.
3080s will also go up in value even more ( because the newly produced cards will have mining limitations on them, so if the crypto craze keeps on going you’ll be able to sell this to a miner for even more cash since it will be a ‘limited’ item.
ps: you could also make around 250-300$ a month with 0 effort by mining on this. The other guy already knows this and plans to do just that prolly.
