Caporegime
That just looks like a gloomy version of the old map.
To sell more season passes, duh.Haha, just looks pretty much the same. What was the point?
Has anyone tried DLSS yet?
I just had a quick go in multiplayer, I seem to gain about 20 fps switching it to performance. From 150 to 170 fps at 1440p.
you tried with ray tracing?
Do you use custom loadouts?Dont know if thats something resurgence related but I have never had that happen to me on either a loadout or a buy station in almost 100 hours of play on warzone
Did they add attracting this season?
Edit: I know it was always selectable but thought it didn't do much?
Weird, the getting stuck happens to all people I play with (including randoms)Yeah, got 3 main ones, I generally pick up 2 loadouts per game (one with a FARA83 and one with a sniper)
When it happens we have to prone crawl away to get 'un-stuck' Highly annoying
I have all loadouts used and chose depending on what teammates are equipped with, where we are on map, how far into circle, ammo I have etc. I'll usually go for bullfrog ghost in certain areas of the map but pick an AR if in more open ground. Sniper / rocket depending on what teammates have as theres no point having 4 snipers and no anti vehicle
Bizarre, can truly say I've never encountered it
I think it must be if you're too close to it and/or prone. I usually slide right up against it, then prone behind it depending where cover is needed.Bizarre, can truly say I've never encountered it
Try sliding into on and prone then next time one drops
Where does headphones come into it?
Yes, there are players always moaning about cheaters, because there are cheaters and always will be in free to play games
You usually always hear them through the walls before they can see you knowing their precise location then pre-fire. Hence I've seen many games. "Cheater!1111 H4X, reported"
when i play on a multi storied building i can hear footsteps but have no idea where they are coming from and which floor above or below they are hahaha its impossible to work out
Download Dolby Access for Windows 10 and enable gaming mode for Dolby Atmos
Gives you a lot more verticality in the sound information
Amazing difference to me on stereo headphones
