1440p
score 14740
rtx3090 @ 2100
5950x @ PBO
466.11 Drivers
https://i.~ibb.co~/p1HwvKk/Untitled.png
Lovely job1080p
3080 FE @ 2130/5200
5600x PBO
466.11 Drivers
1440p
3080 FE @ 2130/5200
5600x PBO
466.11 Drivers
Hi Kaap, can you help! The bench won't run now after doing the following:Scoreboard updated.![]()
MSI bios update to latest for RSB
MSI vbios for 3080 updated (Resize Bar enabled)
Latest GeForce driver installed
Win 10 clean install.
No idea, no error message, nothing happens when launch button pressed, weird.
Ok. Not just Neon Noir bench, can't run Origin client either, so may be a bigger Win 10 issue, but thanks.I have not experimented with Resize Bar yet.
Having said that you could try going back to an older motherboard bios to see if the bench runs at all, this won't solve your problem but it will give you an idea where to look.
Aha! So it does give a boostTry and reinstall the bechmark/app, FYI I'm running the latest MSI mobo BIOS and also the resize bar bios on my 3080 and it runs fine.
... tried reinstalling nothing happens so have contacted CrytekNo idea why, but my 1080p score is worse after the following:Try and reinstall the bechmark/app, FYI I'm running the latest MSI mobo BIOS and also the resize bar bios on my 3080 and it runs fine.
GTX 970 @1475/3900
i7 4790k @4.7 GHz
457.30 Drivers
1080p - 3838
https://i.~ibb.co~/5FSP4Ks/Screenshot-2020-11-16-15-41-48.png
https://~ibb.co~/60jcvH0
1440p - 2241
https://i.~ibb.co~/KG73W2W/Screenshot-2020-11-16-15-39-39.png
https://~ibb.co~/CWhmx8V
That's a decent jump!Updated GPU
RTX 3060Ti FE @1845/3500 (out of the box settings)
466.27 Drivers
1080p - 11574
https://i.~ibb.co~/Kjq4n1z/1080p-Noir-Bench.png
1440p - 7204
https://i.~ibb.co~/26rh9DP/1440p-Noir-Bench.png
FE's OC well too ... those scores will only go one way ... bet your, ahem, vintage cpu isn't helping muchYep, grinning from ear to ear! haha
