- 14 Jun 2004
- Newcastle U/T
Them kits are pricey :/ then you need the briks on top lol!
Looking about I think mine is a Weber BarBKettle
No one build 100 brick bbqs anymore? They work out pretty cheap.
It will work the same as any other bbq you put coals in........fineI've just bought a £50 Argos special!
https://www.argos.co.uk/product/5981887?clickSR=slp:term:bbq:1:50:1
Now I'll just have to wait and see how she performs.
But it's not a Weber..
that just means you will be replacing it in a year or so. The cheap ones are fine, its just that they dont last and dont hold heat aswell due to thinner guage metal etc etc.
That makes you an individual.......better than a sheep lolBut it's not a Weber..
Problem with the Welsh, everything comes back to sheepThat makes you an individual.......better than a sheep lol
My neighbour has one of those - definitely get a cover for it, his hasn't faired well in the weather!
just the longevity is allBut it's not a Weber..
The cheaper versions are good. https://www.cyprusbbq.co.uk/
