Yes, definetely AMD did fantastic job at ZEN3 arch comparing to ZEN2. However, they are still behind Intel in this perspective. Below 5950x with 3800Mhz Ram 16-18-18-38 "CR1". My score is even at CR2.
The 11900K is around 55ns in this,
In Sandra Coffeelake is around 85ns Zen 3 around 80ns, the reason its different is because AIDA64 is measuring from the L3 to the IMC where as Sandra is measuing from the L3 to the IMC and back again, there is a small difference between Intel and Zen 3 in L3 to IMC Transfer Latency, its slightly faster on Intel one way but slightly faster on Zen 3 full round, it isn't enough to make any real difference.
Again this also has no effect on games. That is (Again) Intercore Latency, this is the time it takes for one CPU core to communicate with another, Intel use a Ring Bus for that, Zen 3 use something else, the time it takes for one core to communicate with another in Zen 2 is around 53ns, for Coffee Lake its around 52ns, slightly lower, in games Coffee Lake and Zen 2 are about = or Coffee Lake is a little faster, the clock speed difference makes Coffee Lake that much faster in reality.
For Zen 3 the time it takes for one core to comunicate with another is around 30ns, roughly 40% faster than Coffee Lake and Zen 2.
So, when you look at low resolution gaming slides, and i have lost of them, i'll give you one example below.... where the high frame rates depend on the very fast intercore comunication Zen 3 is streaks ahead of Zen 2 and to a lesser extent tho still significant also Coffee Lake.
