Not far off given all the stuff installed on my machine
Stuff running in the background certainly can have an effect on the score, i do turn everything off before doing a run, through the task manager.
Undervolting Ryzen 5000 is always one answer, Negative Curve Optimiser, i'm running -15 and +150Mhz, runs 5Ghz on all 16 threads all day in games.
Its about time AMD was firing on all cylinders again and these chips are just ####### brilliant, its also nice to see new innovative ways to tweak CPU's, Curve Optimiser seems like such a simple thing but its very clever in what it does, "Take off 40mv" is so 2008, this knows how much or how little voltage to remove or add for everything that it does and dynamically makes those adjustments literally from 1 milliseconds to the next to give you the most optimal results.
I would agree with that. However, is so easy to try with just a few settings. The reason I created the post.Only easy if it works
If I run those settings on my 5800X the PC will reboot before I even start up Cinebench![]()
Nice, are you going to push the offset more? I’m using LLC to dampen the voltage over shoot. Which brings down the peak voltage when the load changes.I got my 5600x running with a -30 on CO and a -0.05 offset with LLC at level 1 with no errors. It maxes out at 65C die temp and 1.13v SV12 TFN with prime 95 max stress and sits at 4650mhz under load. I finally got a decent chip after years of mediocre ones.
With a good chip it’s looking like you can possibly run at 1V under load which is pretty amazing. Trying to get a feel of the chip.
My previous 8700K is a sweet chip too. So the undervolting gods have been kind
That’s currently what I am doing. If you disable PBO and play with the curve optimiser, suggest negative -5 all cores to start with. You should see a significant reduction in temperature. If your stable you can push it to -30, suggest doing it slowly, depends on chip. If things start to get flaky you can tweak individual cores. Give it a try.Is there anyway to undervolt this on stock clocks to actually bring the temps down, i am playing roblox with my kid at 82c :/. Don't get me wrong i am only using 50% fan speed atm which is audible already so i could crank them up and get it cooler but the noise is just to much. I have read pages and pages of pbo/pbo2-curve optimizer and nothing really explains just a plain old decrease in core volts.
Sounds like you have found the limits of the chip.If I go any lower I get random errors and lockups when idling in windows.
Yeah what's weird is that it will run the stress tests just fine down to -0.075 offset and won't boot at -0.1 offset.Sounds like you have found the limits of the chip.
Advanced/ AMD Overclocking.
Disable PBO Limits. go into Curve Optimiser. Negative -5 All Core to start with.
That's definitely on the edge. I would have probably back off to -0.050. LLC could help with stability. Curve Optimiser will give you the biggest gain. The offset is just icing on the cake.Yeah what's weird is that it will run the stress tests just fine down to -0.075 offset and won't boot at -0.1 offset.
