Caporegime
- 18 Oct 2002
Got some people excited with the original story though.
:eggplant:
but a 2060 managing 49fps at 4K with max settings and ultra RT is pretty impressive
Let's not forget that nice minimum too![]()
Personally I wouldn't use performance mode, but a 2060 managing 49fps at 4K with max settings and ultra RT is pretty impressive
The blur is caused by DLSS + HDR at least for me. If I disable one of the two the blur is gone.I just played it on my 3080FE but apart from the shadows and GI I would honestly not notice much difference from the standard game. Framerate is around 85-95fps at 1440P Ultra without DLSS. Tried DLSS Quality but I can always notice the slight blur so disabled it again.
not minimum, average fps for dlss off and on, read the axis and key on graphs don't make assumptions
I didn't enable HDR. It is 1440P 165Hz and I have noticed similar blur in other DLSS games so I guess DLSS is really beneficial for 4K or if you really need the performance.
SIR YES SIR!! (have to admit it was just a glance)
edit - DAMN that's a hell of a boost that DLSS gives!
I notice the blur quite a bit in cyberpunk and in some areas for control (mainly shattered windows) but for this so far, finding it very hard to see the ghosting/motion issues.
If you haven't done so already, try disabling the fullscreen optimisation, I always do this anyway as it gives me a smoother and higher fps experience.
Does seem like there is a more severe ghosting problem with hdr and dlss in this looking through reddit though.
I get over 80fps without DLSS which is fine for me so why bother with DLSS?? Native is always better imo.
