M16FB1 is single rank, M16FE1 is dual rank.
However, you won't know what you're getting until it's in your hand because retailers don't tell you this level of detail.
You sure? I thought the M16 / M8 at the begining told you if it was dual or single rank?
Ah ok, I thought maybe Crucial had changed things up as Tejstar was asking about the code M16FB1 - so it sounds like dual rank B die then?
Only thing I can find for M16FB1 is Crucial Ballistix 2x32GB RAM mentioned in HardForum.
Did you have the sticks in hand Tejstar?
You are probably right, I rarely use more than 32GB, only when I use FinalCutPro for 4K editing or Ligtroom to stich big panorama photos, that I don't do often.Why do you need 64GB? If you don't need 64 GB, then sell the B-die sticks.
Yep, in hand. I ordered a 64GB kit (2 x 32GB) and was surprised to see the M16FB1 extension once they arrived, as hadn't seen that mentioned before - only the M16FE1.
It's annoying that there's no clarification whether these are single or dual rank on the box. It's part of a new build I'm doing so I can't even fire it up yet to see if any software helps me determine whether it is single/dual rank!
If you take a look under the heatspreader (without taking it off) you should either see chips on both sides of the ram stick which means dual rank, or chips on one side of the stick with the other side having some sort of filler which means is single rank.
J10 - did you get the ram from overclockers? I see there is some in stock, I asked CS if they could take a look at the number on the ram but they can't at the moment![]()
I don't think that a solid way to determine single or dual.
@Tejstar get on crucial.com live support chat, tell them the full code and they will tell you. They are good with questions like this.
I found this thread because I bought 2x16GB of BL16G36C16U4B and I found they are M8FB1 single rank, I noticed it had less bandwith than my old (very overclocked, not fully stable at 1800) memory.
I decided to order a second pair to go 4x16=64GB and make them dual rank, to my surprise the new ones arrived and they are M16FE1!
So I did some tests, if I mix them (I don't know what's the best way to mix them) the performance was the same as the M8FB1. Then I tried the M16FE1 and they are indeed faster, here are the tests...
I was not able to get post beyond FCLK 1866 on either memory, probably I need to increase other voltages to get there but did not try further.Can you overclock the M8FB1 sticks higher/tighter?
The BL2K16G36C16U4BL is the RGB version, you may get either Single or Dual rank, you will only know when you open the box and see the number inside (or using sw).Is any of this RAM available in single rank 16GB DIMMs with RGB?
Great, thanks.The BL2K16G36C16U4BL is the RGB version, you may get either Single or Dual rank, you will only know when you open the box and see the number inside (or using sw).
M8FB1 is single rank
M16FE1 is dual rank
