- 27 Jan 2003
- Chesterfield, UK
Ahh yeah that's what i thought, havin a tinker with it.
Say i make it to -15 all cores and it crashes how would i know what core is causing it?
You would go to single core and back off each core individually. Depending if its a light application crash, Prime95 should show you which thread is falling over. Usually the Gold and Silver cores should be fine ( Ryzen Master will tell you this ) so you can discount those. It all depends how much time you want to play with it. If you not that bothered, just back the all core value.
Testing is key. Cinebench R23 and 20 Minute Prime 95 with large FFT. Hwinfo to monitor the cores and WHEA errors. Oh and a little book to make notes
