Yeah I read quite mixed reviews of that one but was going to get it - but out of stock locally for me. Several unknown ones from Toolstation I couldn't find reviews for. But found the Amazon one with similar reviews to the Draper and other low priced ones with next day delivery. Neo is now sorted - but a combination of an axle and o-ring reallyI use my car torque wrench branded by Draper. Never let me down and can be bought from most auto factors
Something like this
What are you comparing them to? I'm out of touch with rim brake prices, but the Zipp 303S are similar price, just a bit heavier (but are wider and more of an all-round).Merlin doing Vision Metron SL 40s at a cracking price currently. £999.
40mm carbon clinchers 1400-1450g.
Zipp or similar are heavier and twice the price!
Im sorely tempted but it’s more than I want to spend!
Although you'll have to be careful with Zipps and your tight clearances - their latest offerings are increasingly wide, the 303S is 23mm and the new 303 is 25mm internal. They are both disk ones though.
Sounds like an annoying feature, especially with crappy data/gps tracks able to catch it out! There's still a bunch of 'cat 4 hills' around here from rubbish GPS data. As mentioned it did use to be much worse!No but it reminds me of when strava was quite fresh to the scene. I used to go out and noticed a new 'KoM', when you looked at many segments they were negative net climbing so were basically downhill and thus not KoM in principle at all lol.
The 'climbing' page on the ELEMNT can be customised to include what data metrics you want alongside the climbing bits. Have VAM and Gradient on mine alongside 5s and 15s power.
Totally this - just fatigue and boring roads. Especially on the 'home stretch' as it's all stuff you've seen before so nothing to really distract. Nothing worse than 'counting down the miles' with sore legs! The times I do it I get very annoyed with myself, I usually try and distract myself with some higher cadence or standing drills just to vary things. Stretching out to relieve some strain, or spinning to legs out to also do similar - usually find my cadence is flagging or all over the place at that point anyway...! Although quite different to getting to that point where you're considering calling for a lift home on the last hill! Counting pedal strokes and measuring the effort into each one works for me at that point. Like a countdown - it has an end, but count up as never sure where it'll be!maybe I needed more time to recover? The last 20 the saddle was hurting, my legs had gone and I just wanted to be home, which doesn't happen often. (The last 20 were also roads I've done many times, so you lose the enjoyment a bit because of that).
Still, really enjoyed the ride up to the that point, some lovely roads and I've actually got some sun burn!
