- 6 Jun 2011
Looking fantastic mate, good job.
Now to start planting?
Now to start planting?![]()
Nice work well done
That is stunning mate really well done, I do wish I had a larger garden![]()
Wow that's a powerful pump, probably an overkill for a spray gun. I have something very similar, use it with a 19mm hose to move water from lower tanks up to higher tanks but the flow rate is too much to use anywhere near actual plants without blasting them out of the ground.Thanks Amigo,
I ordered this today https://www.amazon.de/gp/product/B08J452B57/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1 to use my spray gun directly from the IBC![]()
What a wonderful build @easyrider , insanely jealous - my current yard is smaller than your tunnel (joys of a mid terraced house).
How big is your garage roof, don't think my house roof even catches that much water!
When using 19mm hoses which are far better than 13mm, you only need ~1m of head from an IBC to achieve perfectly decent flow rate for watering. In a polytunnel it's a good idea not to spray everything, try and keep leaves dry, the damp and high humidity can be bad.
I do most of my polytunnel watering with mavity fed drip lines, and the bits that aren't plumbed in I tend to use watering cans. It's great to water half the tunnel with a single turn of a tap.
Our whole site is on a gentle slope, I store 8000 L off the house & veranda which is around 3-4m higher than the big poly some 30m from the house on a lower terrace.
But I also have a smaller poly, where I just have an IBC on a bank only a foot or so higher and that's enough head for the drip line/watering with the 19mm hose.
We have a couple of these round the back of the house, they are over 2m tall which helps with head and reduces their footprint:I think I need a few more IBC’s![]()
https://www.tanks-direct.co.uk/enduratank-3000-litre-water-tank-non-potable/p534
It's a very nicely put together polytunnel you got the sheet nicely tight and even, good job.
Honestly, the impression I got of you from your postings was of some all-thumbed useless git. I can hold my hands up though and say I was wrong - that's a really impressive job and some decent graft. My back was aching just from looking at the trench you dug to mount the posts.![]()
This was hard work but the Pond build was Epic.
