I pumped some water from the car port Butts through a hedge to a container located as close to the entrance of the Tunnel to dunk my watering can. Multiple dunking was not fun
. After watering the tunnel I went inside and ordered that pump so I could use my spray gun instead from the IBC
I can easily pump this 630 litres from the carport to the IBC to top it up . There is power there and I’ll use the IBC as the main pump station area. @clv101 is right I need a bigger water storage solution certainly add to the capacity I already have which is around 3700 litres . I still need to gutter the polytunnel aswell going to use 16mm electric trunking.
I would love an underground tank next door to the polytunnel so I could direct water off the tunnel to it.
I can easily pump this 630 litres from the carport to the IBC to top it up . There is power there and I’ll use the IBC as the main pump station area. @clv101 is right I need a bigger water storage solution certainly add to the capacity I already have which is around 3700 litres . I still need to gutter the polytunnel aswell going to use 16mm electric trunking.I would love an underground tank next door to the polytunnel so I could direct water off the tunnel to it.
