- 28 Nov 2018
- Monstrocity
That's nowhere near as slapdash as I was imagining!
Bumping this thread as I've finally got around to upgrading my system to a Ryzen 5600x and should now be capable of getting the best out of this card.
I'd like to flash the bios to Vega 64 and also understand the best thing to do to get the most out of this card is to undervolt but I'm an absolute beginner and was hoping someone could point me at a guide (for beginners like myself!) to show me really clearly how to do both.
Thanks in advance for your help
Did you flash the bios first or just leave as is and follow the guide you just posted?
Ok cool thank you, just watched that guide on youtube and really clear, I'll give that a go as a starter and wait to see if anyone can advise if it it worth flashing the bios to squeeze some extra performance out of itI just left the original BIOS on it.
I hope I never need to replace the cooler on any graphics card. From what I've seen in videos I'd probably pull my hair out. Good that it worked for you eventually.
What I was a bit surprised with reading this thread, is a couple of people reporting hot spot temps over 100°C and pretty large differences between core and hot spot. Does it take a lot of time for the hot spot to settle? Is is very game dependent? I've run a match of War Thunder in 1440p everything maxed out and it went a bit higher (17°C above core temp) than with Furmark (14° above core temp).
By the way, you can breathe some extra life into your Vega 56 in War Thunder by switching to DX12. It gave me +15% fps over DX11 on Maximum preset in 1080p. It beats a Sapphire 5700 XT running in default DX11 mode.
How is everyone getting on at the moment with their Vega 56? My saphire Pulse is still preforming admirably - im curious to see what clocks people have on the core and memory please?
