The Official Pizza Discussion thread (was: Cooking Neapolitan Pizzas with the Uuni 3)
18 Feb 2007
London
I’m sure some make there own, but what tomato sauce do you use for the base, I’ve been using these small jars from Sainsbury’s, which are not best really.
Also is this nduja a paste, does this replace the tomato base or more of a topping?
9 Apr 2007
I use tinned chopped tomatoes reduced down. Nothing else added.
25 Feb 2004
Hampshire
Usually tin of good tomatoes, bit of salt, sugar oregano and basil and some garlic, blended up then reduced down for 30-40 minutes on a low heat. Occasionally chuck in some chillis if I want a bit of spicy.
9 Apr 2007
I read something that says you shouldn't blend them as it breaks the seeds which can give an unpleasant taste, should mash them instead.
25 Nov 2005
I can't find a really nice tinned tomato for pizza sauce, Napolina comes best out of what I can find locally but I find it needs some extra puree and sugar to get it tasting nice, apart from that just some olive oil & dried herbs (Marjoram is great) all blended together.
14 Jan 2018
Hampshire
San Marzano tomatoes are meant to be the best but a bit pricey. I wasn't blown away when I tried them.
Don
18 Oct 2002
Notts
just buy a 4kg can of Mutti sauce, split and freeze it, as good as anything you will make
9 Apr 2007
Neither was I, thought I was the only one. One of those ingredients that doesn't justify its price.
Decent chopped or plumb tomatoes are just as nice if you ask me.
27 Nov 2004
North Beds
4 to 6 week delivery though
Koda 16 is in stock on Selfridges website, mine turned up yesterday :)
Had a play with it today, had to put it in the greenhouse as it was rather inclement weather...
Garlic + mozerella pizza bread to start:
Getting the hang of it i think :)
As it was my first go, I used dough from here to focus on learning how to use the oven. I will progress to my own dough soon :)
1 Mar 2010
so Mutti sauce
"Tomato99.1%,salt,basil0.075%,oregano0.05%, onion 0.05%, natural flavouring." ?
that's probably onion powder, which might be interesting to buy and add into chopped tomatoes versus (less finely) diced onions/celery I currently use and cook in.
Mutti finely chopped tomatoes look interesting, since I don't liquidise mine, and, that would change texture,
but otherwise their non Marzano ~80p a can, slightly more than 60p we spend on Italian cirio chopped ones, on offer @waitrose/js
what's the typical diameter of pizza's folks make in Kodis etc ? those look like 8" ... I had naively thought of making fuller size 12"'s if I had a kodi 16",
but maybe that doesn't pan-out due to additional handling problems/pell .. say. ? ... so the standard kodi would be fine - albeit more even heat distribution on the 16" might carry it.
27 Nov 2004
North Beds
so Mutti sauce
mine were only 8-9 inch but that's because I'm crap at getting the dough stretched well enough :D I'm launching with a 14" peel and turning with a 9" turning peel.
That being said, having the flexibility to move the pizza away from the burner was definitely yielding better results than the ones cooked nearer to it (even with the burner set to low). I'm personally very glad i went with the 16 so i have the flexibility.
Caporegime
22 Nov 2005
because most tins of tomatoes are sour and taste horrible they aren't sweet like tomatoes are supposed to be
Permabanned
23 Apr 2014
Hertfordshire
Arrived, setup, made dough this morning, first attempts. :D
Son made chicken, mozzarella, pepperoni.
Pepperoni with chilli for me.
Happy with those for a first attempt but need a different dough recipe, it was not quite right. The crust was stodgy and seemed like it needed longer but would have ended up well burnt. Need more practice to get the edges a little thinner I think.
Dough was just 00 pizza flour, semolina flour has not arrived yet. Will be trying the dough recipe/method from the first page next time.
