RX 5600 XT - Cannot change resolution past 640 x 480
13 May 2021
Leicester
So I just received my PC back from an RMA, and it has a different GPU than when I sent it out. This wouldn't be a problem, but now my screen it stuck on 640 resolution and I cannot change it: the box is greyed out. Before I was running at 1920 x 1080.
I have tried removing and updating the associated drivers, as well as installing the Adrenaline software, to no avail. If you need any other specs I can send them, but as it was fine pre-GPU change I figure there's some disconnect between the new one any my screen.
Any help would be appreciated!
OP
13 May 2021
Leicester
Did you successfuly remove and update the drivers as you said you tried ?
Download ddu , uninstall all drivers then reinstall new.
https://www.guru3d.com/files-details/display-driver-uninstaller-download.html
The ddu worked great, let me put on 1920 resolution. I went to reinstall the drivers again in the device manager, but said I had the latest. So I downloaded the AMD software to get the drivers, but immediately it went back to 640 res.
Do I just not update the drivers / avoid the AMD software?
Man of Honour
23 Mar 2011
West Side
Confused why it would say you have the latest drivers after you uninstalled the drivers .
Try an older driver version reading online that there has been problems with the layest amd driver locking resoloution to 640.
https://community.amd.com/t5/driver...-3-1-locked-my-monitor-to-640x480/td-p/458529
OP
13 May 2021
Leicester
Yeah I was confused too. I ran the ddu a second time, after the latest drivers failed. And now it told me it could update the Basic Windows Display Driver, and downloaded the Radeon driver again, breaking the resolution.
Just tried to install an older driver but it still locks the resolution with the Aug 2020 version (oldest on the list when I looked)
The RX Vega I had previously had none of these issues so I'm as confused as I am frustrated as to why my freshly repaired PC is giving so much grief
Man of Honour
23 Mar 2011
West Side
Its strange they replaced your gpu and didnt install the drivers to test the new gpu works, thats lazy.
Your Going to have to give them a call and maybe send it back.
Man of Honour
23 Mar 2011
West Side
Yeah, I see a lot of talk about monitor firmware and gigabyte + amd not fixing driver issues. I'll have a go at changing the firmware but don't think I scan do it. Using a TV not a monitor
Can you get hold of a monitor to see if the gpu works or take your pc to a friends to plug into there monitor ?
OP
13 May 2021
Leicester
Maybe try a new HDMI cable for your tv, what other connection are on your gpu ?
What model 5600xt is it ?
I've tried two different HDMI to no avail. Also tried the VGA > HDMI on the tv and also doesn't work. I have 1 HDMI output, and 3 DP outputs
Model is a Gigabyte Radeon RX 5600 XT
Man of Honour
23 Mar 2011
West Side
Vga to hdmi on the tv confused as the gpu doesnt have vga unless the vga on the tv.
Presuming tv connection is hdmi .
The only other thing to try would be to get a dp to hdmi cable.
18 Oct 2002
Manchester
Have you reseated the card? If you received the PC back from repair in its entirety it's possible the GPU has come slightly loose in the PCI-E slot during transit? I say take it out completely and re fit it, including any PCI-E power cables just to make sure.
OP
13 May 2021
Leicester
Yeah VGA is on the tv, HDMI on the board.
I've contacted OC to see what they say, I'll look into the cable also
OP
13 May 2021
Leicester
I gave everything a gentle press, just in case I dislodged something when removing the foam filling. But I'll try fully reseating the GPU and cables too
