Hi, Got the PC after a few day`s at the shop, there were quite a few problems, most were down to the actual build and setup. The water cooling system in the bios was tiered wrong, instead of running 100% 100% of the time it was tiered at 1, 100% 2,75% 3,50% and so on, so as the CPU was getting hotter the cooling system was getting slower. The entire cabling system has been though, found the extra support bracket to support the GPU in place and aid with the size and weight was 1 slot lower than it should have been, so a very slight chance the card could have lost connection with the MB, also the 8 pin socket wasnt fully connected properly. So a possible loss of connection. The Adrenalin software from AMD is still messed up till they fix it, I have to leave it on standard settings with a custom fan arc. He`s managed to bring the max temperature down by 20 deg C, so under full load doesn't go above 85c and the fans kick in at 3,500 rpm instead of the standard automated settings of 1,500 rpm. He`s had it running flat out several day`s with no issues after fixing the problems and got it back and ive had no probs either, so im happy. for the time spent wasn't expensive either, only charged £35. Also said dont update the BIOS in future as it will need reconfiguring. Only current issue he cant find is the case fans speeds are not adjustable though they should be.
