- 28 Oct 2020
I bought an aqua D5 Next pump. It came with 3x m3 and 4x m4 screws. I want to attach the pump to a mount at the bottom of the pump using the 3 holes in the bottom of the pump. But the 3 screws included are too small! They just slide in and out. The other 4 set of screws are too thick.
Maybe I am misunderstanding something but how is it possible that they supply 3 screws that don’t fit?
Has anyone had the same issu?
