Hey guys,
I booted up my PC around 10 minutes ago, and unfortunatly the boot problem still persists..
Wont let me access the "Start" menu via keyboard and then Spotify plays up and is unusable, the solution is to restart straigh away and then boots into W10 and all is good.
What I want to know is, can I leave my PC in Sleep mode all the time (even overnight)?
As it awakes from sleep fine, the only thing im unsure about though is that, when sleeping the whole PC goes down, apart from the Corsair RGB RAM im using, the, RGB on this stays on, the only indication that the PC is not turned off (apart from the power LED changing to blink to let you know also).
So is that still OK, or am I better to shut down at night?
Thanks for reading!
Thanks for reading!
