- 21 Apr 2013
Hi. I have managed to get my hands on a PS5 but the problem is I only have a 1440p monitor which as you know , it doesn't support. The monitor I have is a Dell S2417DG 27". I use this for my PC gaming.
As far as I know, this monitor wouldn't support upscaling to 4K either so I suppose my only option would to be buying a new monitor which is going to be costly. The other option I suppose is holding out for Sony to release an update which they do support 1440p but that doesn't seem to look likely does it?
If I did go buying a new monitor route I'm confused as to what I should go for as well. I play a lot of shooters so I'm reading 1080p would be the way to go for 120hz so I'm not at a disadvantage but then I would also want to play some PS exclusives and feel like 1080p is really not getting the most out of a PS5.
Lots of question, little to no idea.
Help!?
Help!?
