Office 365 Email Setup
25 Jul 2009
England
Hi guys,
I am setting up my domain with the office 365 email system.
I've gone into 123-reg and added the TXT file (copy and pasted) from the login.microsoftonline.com admin - domain setup page. It's been 12 hours and it still hasn't been verified. I can't proceed to the next step until the TXT records have been updated. The next step is then to do the MX records.
The three videos i've watched all seem to work within 10 minutes.
Should I just keep waiting as it does say 48 hours it could take?
Thank you
Once you added the TXT record for MX= did you go back into your admin panel to verify?
Post a screenshot of the TXT record from your 123-Reg DNS records.
All i've done is add the one TXT record as requested (not sure I should be changing anything else yet?)
https://i.~ibb.co~/BnYjNBx/Capture.png
I didn’t say add it to the domain what I mentioned was to verify it through command prompt (CMD) :)
I've emailed 123-reg because all the guides say copy and paste the MS=ms81110216 to a "TXT record" in the advanced DNS settings on 123-reg and it will verify (extremely simple). Starting to think is there a problem with the domain somewhere. I purchased it 2 days ago now.
Looks that way. I've created a ticket with 123-reg to see what they come up with.
Thanks, appreciate the help
They will fix it so it's pingable, there might not be a name server (NS) set on the domain. You should have a control panel with 123 reg to verify that setup. Did you just buy the domain or with hosting as well?
Have a read of this before 123 reg contact you to fix the issue.
Change nameservers to set up Microsoft 365 with any domain registrar - Microsoft 365 admin | Microsoft Docs
I just purchased the domain through 123-reg then office 365 business from the microsoft website for the email hosting.
123-reg said it was an SOA error. Took them 2 days but I had it setup in minutes once they sorted it. Wasn't me being a numpty after all :D
Glad your sorted now, I would move the domain to 20i personally if you don't have any other services with them.
