Did you self install the tado?
What do you think of it? How was it to fit/install? My alternative would be hive but I see mixed reviews on amazon etc.
Considering getting one myself with TRVs. Am I correct in saying the TRVs just bolt on to actuate /move existing valves?
P.s. Did you get a good price anywhere, let me know!
Yeah it was fine.
Took the ancient looking thermostat off. (it was yellowing! Eww)
Was a 240v connection.
Turned the breaker off. Checked wiring (and asked on here) tested to make sure power was off.
Screwed in wires.
It's not fixed to wall yet as getting plastering done. So no point yet.
It then downloaded an update. All. Done.
Trvs are even easier.
'pair' in the app
Remove old (just unscrews)
Put on new one.
Auto calibrate
Other option was hive. But went for tado. Nest wasn't an option as no trvs. Trvs are the most important thing. This is a small detached house with a lot of windows. So some rooms bake, others are cool. In my study without smart trvs I'd be roasting or freezing.
Why didn't I go for hive? Basically aesthetics.
I think the app and devices work better. But functionally I think they are identical.
Cost?
40 each trv (cex and eBay) - 4x
40 for the main thermo and bridge (ebay, brand new) - 1x
20 additional stat - 1x
Total outlay so far - 220.
I think this looks like a bargain vs new!
Got two more rooms to add. Less urgent. One is the gfs work room. I said it's up to her if she gets one. Other is ensuite. Might not bother. Not really worth it.
Not doing the utility or hall either
By chance I got a V2. So got geofencing for free.
Edit.
I don't have a combi. This is an old tank set up. So I didn't get the hot water control. As I just have that on an hour a day. Might add it on in future. But probably not.
Oh. I think it's made a difference already. But the old thermostat was so bad. Set at 20 it wouldn't come on until 17.and turn off at like 23. And it was in the North facing main entrance! So my south facing study would be being heated while getting sun and get to 27c!
