I'm looking at HWINFO and running "Dying Light" and all the temps on the gpu seem very high. is this normal or should I request a RMA for this card?
gpu temp is 67c
memory junction 96c
hot spot 79c
so thats normal temps then?
my case is a HALF-X so its well ventllated, im just not used to seeing those type of tempretures
For rtx3000, anything under 100c on memory perfectly fine and anything under 80C on gpu core is perfectly fine
They really should stick something on the box or in the monitoring software to tell people what is acceptable with these "new" temp sensors they have started having lately. The actual core temps seem to be the same or lower than I've seen on many cards over the years.
His cooler is the 4 slot cooler though so he is worried why it's not cooler.
