with a 100+ litre boot space
https://poolstockcarsales.co.uk/cars-for-sale.php?p=1888
No idea on reliability, or if the trim level is any good - but it's a 1 prev owner. Not too far from you either, should be able to barter price down a little.
I dont know much about ford engines, its a 1L ecoboost better than a 1.6?4K seems expensive for a non ecoboost car
and it's done 70K
Is a 1L turbo more reliable?
Isn't a 1L turbo stressed more? For his budget it won't be a low miler
Description says nothing about it
You will need to make sure both belts have been done or get them to do it for free (bargaining chip)
If its got full service history, hand book and 2 keys worth a look
The 1.0 ecoboost had a few problems.
All of which have been solved via recalls![]()
HPI check is clearBefore you buy it do a vcheck on the vehicle
They also fixed the carbon buildup and low fuel pressure problems?
There was also a recall for clutch slip/overheating, which had the potential for the clutch housing to burst, rupturing fluid lines and cause a fire (which was also misrepresented in the press as being an ecoboost issue)They only replaced the leaky coolant pipes afaik, which stops the most obvious overheating issue.
